Auto sensor drying cycles heat for about 10min, then stops heating, but still runs. Ducts are clear. Timed heating works fine.
It sounds like the secondery coil is not coming into play on the gas valve. I would replace the coils on the gas valve. Tom ApplianceEducator.com
