All Wet
#1 Posted : Thursday, May 5, 2011 10:05:44 AM(UTC)
All Wet
My second Maytag, both have run water in and out non stop. When it fills to rinse it will not stop, water just goes out the drain. The other one I had did the same, I gave it to a friend and he has hsd no problems. Maytags must not like me.
ThatGuy
#2 Posted : Thursday, May 5, 2011 1:14:46 PM(UTC)
ThatGuy
Groups: Expert
United States
Its your drain.
What is happening is the drain is either lower than the top of the washer or it is a "sealed" drain that is causing a siphoning action. When the washer fills the first time, everything is OK. When it drains then starts to refill on the rinse, the water just keeps on draining. Its being siphoned out.
What you need to do is fix the drain, If the drain is high enough, then the drain hose is probably sealed to the drain stand pipe. You may need to install an anti-siphon valve. Like this one. Part Details - WHIRLPOOL Syphon breaker, part number: AP3073577
All Wet
#3 Posted : Thursday, May 5, 2011 2:21:56 PM(UTC)
All Wet
Originally Posted by: ThatGuy Go to Quoted Post
Its your drain.
Thanks That Guy, makes sense, second washer that's done this. first one still working fine. Is next on my "to do" list. Will report back with results.
All Wet
#4 Posted : Friday, May 20, 2011 10:35:55 AM(UTC)
All Wet
That was it!! Problem solved! Drain hose was tight fit into drain, not allowing any venting. repaired and working fine! Thank you gentlemen!
