My sympton is similar to a previous posting in that the washer fills, agitates and drains but won't spin. It's had trouble starting spinning for several months now but could always be coaxed into spinning by drepressing the lid switch and rotating the tub, but no more. I do not have the black rubber shavings underneath but do notice some transmisson grease. Is a faulty clutch the spin problem or something else?
Remove the washer cabinet, start the washer in spin and see if the clutch drum spins. Post the result.
Gene. P.S. Does it make any unusual noises in spin?
visible clutch housing underneath does spin, no unusual noises
