hookele
#1 Posted : Tuesday, May 3, 2011 11:47:21 AM(UTC)
hookele
Hi -
I have had a black mildew / mold covering the inside tub and racks for quite some time. We cleaned it out but it has since returned. I am trying to determine the source of the problem. I have replaced the drain pump recently so am confident it is draining. I am concerned the HEAT DRY option is not working or possibly the heating element is burned out? The plastic dishes will always be wet at the end of the cycle, even with a rinse aid. The plates and such will dry but that is about all.
1. How can I verify the HEAT DRY option is actually functioning?
2. Is there any other troubleshooting that may help?
Thank you much for any assistance!
#2 Posted : Wednesday, May 4, 2011 1:58:27 AM(UTC)
Replacement parts for FRIGIDAIRE PLD2855RFC0 Frigidaire/dishwasher | AppliancePartsPros.com
See the attachment for the tech sheet
[COLOR="DarkRed"]
1. How can I verify the HEAT DRY option is actually functioning?[/COLOR]
Open the door during heated dry to see if the element is hot.
Just be careful that youu do not burn your fingers.
Could also run the diagnostics in the tech sheet to see if it is heating up.
[COLOR="DarkRed"]2. Is there any other troubleshooting that may help?[/COLOR]
Unplug/remove power from the unit.
Measure across the hi-limit thermostat and heater with a meter.
Should be about 15 ohms.
If open disconnect one wire at the hi-limit and measure it, should be 0 ohms.
If infinite ohms it needs replacing.
If closed (o ohms) measure across the heating element, should be 15 ohms approx.
If open it needs replacing.
If the above are OK and the wires from the control board to the heater are OK then the control board is probably shot.
To kill the mold add a cup of bleach to the unit during the first wash.
No dishes and no detergent.
Let it run for a couple minutes and then stop it and let it sit for 15 minutes.
Then let the cycle continue to the end.
Once doe leave the door open for half an hour or so, to let any residual chlorine dissipate.
File Attachment(s):
PLD2855.pdf (651kb) downloaded 10 time(s).
hookele
#3 Posted : Friday, May 6, 2011 10:47:11 AM(UTC)
hookele
Was able to track down the problem to a loose connection at the thermostat. Thanks so much for the help, this was a huge help. One wash with actual heat and a ton of the mildew came away. Thanks again!
#4 Posted : Friday, May 6, 2011 4:36:15 PM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
