The element in the bottom over was broken and replaced, but does not work. Do I have to replace other parts. Both bake and broil does not work. Thank you in advance for the help.
Remove the rear cover and check all wires. If there is nothing wrong then replace the control board (aka a clock). - The part number for the clock is AP3956392 - The part number for the clock overlay is AP2126491 Gene.
