Carol B
#1 Posted : Friday, November 7, 2008 7:48:04 AM(UTC)
Carol B
The oven temperature is less than selected on the control panel. It will heat to 350 if we select 410 on the control panel, but not consistently. Is this a thermostat problem or control panel or other issue?
#2 Posted : Friday, November 7, 2008 6:14:56 PM(UTC)
Hi Carol,
How did you measure the temperature?
