Hello, my oven has been turning off after a few minutes of working and is showing the error code F2. It starts fine the usually just shuts off or sometimes after a few tries will stay on. I read a few of the threads and think it's the Oven Temperature Sensor(RTD). Any Input would Be appreciated, Thank You.
Hello! Our oven is currently having the same problem although it is showing the F2 & F3 code. We figured out that our sensor is good by checking the probe on the back & using an OHM meter. But we found out we needed a new control board which we just ordered & replaced. Bingo that's what is was...like brand new!
