AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer not drying well. Takes 2 or 3 cycles to dry all the way
I have a stack washer dryer combo. It used to dry clothes in 30 to 50 min and now it takes 2 or 3 cycles of 70 min to dry a load. Could it be the Heating Element going bad or to they just go out? Please help.
Here are your parts Replacement parts for FRIGIDAIRE GLET1031FS0 Frigidaire/laundry Center | AppliancePartsPros.comHere is a wiring diagram http://manuals.frigidaire.com/prodinfo_pdf/Webster/134806300.pdfIt could be the heating coil or something else but the most common cause is a dirty or malfunctioning vent system. Unplug the unit and disconnect it from the vent system. Now try a run. If it now dries OK odds are the vent system needs checking/cleaning. Be sure to check that the louvers on the outside of the house open correctly. If you do not want any lint in the house. Take a pair of pantyhose. Put one leg into the other and then attach this to the dryer's vent. Leave enough room so the pantyhose can balloon out like a windsock. Both the above will let you check the temperature and the air flow. Note: The above is not recommended for gas dryers due to carbon monoxide concerns. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
