My Double Oven Will Not Work. It Will Work One Day Or Hour Then It Stops Working. The Light Will Come On But The Oven Clock Will Not Come On.t Will Come Back On And Then Beep A Few Times And The Go Back Off. When The Oven Comes Back On E6 And F2 Shows Up On The Display. I Need To Figure Out If It Is The Main Circuit Board Or Touchpad Controll Assembly,,,,,,need Help
This is what you need to do.
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nat
