alkatraz
#1 Posted : Thursday, November 6, 2008 12:16:41 PM(UTC)
alkatraz
Hello,
I am installing new drum support rollers for this old Kenmore from 1981,
and am not sure if I am supposed to grease the shaft before I install the new rollers. It seems like it should have some kind of lubrication--any answers?
magician59
#2 Posted : Thursday, November 6, 2008 12:22:56 PM(UTC)
magician59
Wipe the posts clean. Don't add any lube. The lint in the machine would soon make it a sticky mess.
alkatraz
#3 Posted : Thursday, November 6, 2008 12:30:11 PM(UTC)
alkatraz
Thanks magician59, I wasn't sure if I put it all back together would it start screeching -
magician59
#4 Posted : Thursday, November 6, 2008 2:11:46 PM(UTC)
magician59
The sound usually associated with the rollers is more of a rumble. A screeching noise usually indicates a bad idler or metal against metal. There is a repair kit that includes rollers, idler and a replacement belt for Kenmore/Whirlpool dryers. It is used for older units, and will void warranty for newer units, although it is made by Whirlpool.
alkatraz
#5 Posted : Thursday, November 6, 2008 4:06:44 PM(UTC)
alkatraz
Thanks, I mentioned screeching because the posts and the interior of the roller are both metal. The rollers that I removed seemed like they may have had lubrication on them at some point, because at the ends of the sleeve there was a slight bit of black oily or greasy residue, but the posts were shiny and chrome-like without lubrication... I wiped the posts off and installed the new rollers without any lubrication and this dryer is finally quiet again. It was rumbling quite loudly for a bit before due to a broken support roller.
Much appreciated magician59!
Guest (5)
