unhuh5591
#1 Posted : Tuesday, November 4, 2008 3:37:22 PM(UTC)
unhuh5591
The oven door will sometimes lock after a baking cycle. It might not do it right away , sometimes even after it has cooled quite a bit . It will eventually unlock again so it's not a terrible inconvenience but if it decides to do it while the Thanksgiving turkey is on the inside of the oven there are going to be a lot of unhappy guests. Defective oven sensor maybe ??
#2 Posted : Wednesday, November 5, 2008 10:03:11 PM(UTC)
Most likely the problem is a bad control board aka a clock.
- The part number for the clock is AP204806
Here are the break down diagrams for the Maytag range Model MER5550AAW
