My Maytag model MGR5755QDW will not light it stays at 100. No gas smell. gas burners on the top work fine? help
Originally Posted by: jwohlf ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My Maytag model MGR5755QDW will not light it stays at 100. No gas smell. gas burners on the top work fine? help Jwohlf, Remove the bottom panel in the oven and observe the glow bar igniter, after you program a bake cycle, the igniter bar should start to glow, it will take a few seconds the bar should be "white"hot in less than 90 seconds, then it should release and ignite the gas. if it doesnt glow or if it only glows orange/red, you most likely have a weak/bad igniter, Part number: AP4012072
Good Luck, :) :) :)
