StNick55
#1 Posted : Wednesday, November 5, 2008 3:24:03 PM(UTC)
StNick55
The model # is MGR5770ADW on my earlier post of oven ignition and gas flow problem
#2 Posted : Wednesday, November 5, 2008 3:39:14 PM(UTC)
In addition to your earlier post http://forum.appliancepartspros...problem-oven-burner.html, the part number for the igniter is AP205873
Here are the break down diagrams for the Maytag range Model MGR5770ADW
StNick55
#3 Posted : Wednesday, November 5, 2008 3:54:29 PM(UTC)
StNick55
Thanks for the help Gene. The oven seems to be working now. Would the igniter be an intermentent problem.
#4 Posted : Wednesday, November 5, 2008 4:38:55 PM(UTC)
Normally the current drawn by igniter should be between 3.2 to 3.6 amps. If it's very close to 3.2 amps then it'll work intermittently for some time until it dies.
