Need to remove lower washarm for cleaning/replacement and there is a foreign object rattling around. Appreciate any guidance.
Thanks.
Originally Posted by: jdherman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Need to remove lower washarm for cleaning/replacement and there is a foreign object rattling around. Appreciate any guidance.
Thanks. JD, Once you remove the lower dishwasher rack, in the center of the spray arm assembly, there is a LARGE retaining nut, turn the nut counter clockwise and it will unscrew, don't loose the small Nozzle inside, lift the arm and cover of the top then separate the arm from the cover. Good Luck, :) :) :)
