woodyguy
#1 Posted : Tuesday, October 16, 2007 10:08:55 AM(UTC)
woodyguy
Our Machine Will Fill But Will Not Do Anything Else. I Had To Dip Water Out By Hand....fun!!!!
Pegi
#2 Posted : Tuesday, October 16, 2007 10:20:58 AM(UTC)
Pegi
I would start by checking for a broken lid switch...or is the motor running?? If so check for a bad/broken/oil covered belt...
woodyguy
#3 Posted : Tuesday, October 16, 2007 12:27:02 PM(UTC)
woodyguy
Thanks, I checked the lid switch with an ohm meter. It is opening and closing okay. I removed the back cover, turned the machine on. The motor briefly started humming, I smelled something get hot and then the motor quite humming. The motor pulley and belt moved freely by hand. Where do I look now?
Dirty clothes (Washer Repair)
by lucyfish 7/20/2008 2:24:44 PM(UTC)
