Richmaytag
#1 Posted : Wednesday, November 5, 2008 8:45:51 AM(UTC)
Richmaytag
Scenario,
Machine works fine on all cycles but when you take out the clothes, even though there is no water left in the tub and water has been pumped out, are wetter than normal and they take longer to dry.
Older machine with analog controls.
Does this unit have a two speed electric motor? If so is the higher speed responsible for spin cycle? If it is only a one speed unit, since the cycle works, I do not think it is the timer.
Re the belt - it is a tad on the floppy side but could it be slipping under high speed spin load? Is there a tension adjustment pulley on these machines ala that on timing belt on cars?
Is it hard to replace the belt on such a unit ?- looks nasty. The cabinet contents can only be gotten at from either the back or underneath.
abadfish66
#2 Posted : Wednesday, November 5, 2008 8:49:28 AM(UTC)
abadfish66
Do you have a model#
abadfish66
#3 Posted : Wednesday, November 5, 2008 8:57:19 AM(UTC)
abadfish66
If it's the machine I'm thinking it is, the belt is alittle tricky, but not bad. To change it lay the machine on it's front.....This is a single speed motor, and if memory serves me right, the adjustment for the belt is done by moving the transmission to the left as your looking in the tub. Is there oil present?
Richmaytag
#4 Posted : Wednesday, November 5, 2008 1:37:21 PM(UTC)
Richmaytag
Could not find the bloody model number - looked on back panel - nada there.
The unit has a pair of toggle switches on the left side for water levels and temps and on the right one round dial for the timer. That is all.
So you tell me that I can move the tranny over a tad and then will tighten the belt? So U think it is the belt also? I was also thinking of putting one of those no slip compounds on the belt. But they do not really replace a good proper tightening.
Drags1998
#5 Posted : Wednesday, November 5, 2008 2:10:19 PM(UTC)
Drags1998
There are 3 7/16 nuts on the motor mounting plate, I loosen all 3 and put my hammer handle between the transmission and the motor plate and pull to the rear of the washer, tighten the nuts while holding tention on the motor.(a little tricky):)
Richmaytag
#6 Posted : Thursday, November 6, 2008 5:34:08 PM(UTC)
Richmaytag
Will do and thank you much. If that does not do the trick I will get back to you.
Guest (4)
