JMK54
#1 Posted : Tuesday, November 4, 2008 4:02:17 PM(UTC)
JMK54
Dishwasher stopped after wash cycle , Normal wash indicator light is blinking along with the washing indicator light. Powering down didnt help. Suspect touch pad membrane is faulty. Pushing hard on Cancel drain motor will run for a second and touch pad then flashes. Had this problem when D/W was new and factory tech replaced both console and electronic control. Is there any way to test contacts of touch pad on ribbon connector?
v2k04
#2 Posted : Tuesday, November 4, 2008 4:53:46 PM(UTC)
v2k04
get the tech sheet out of ther lower kickplate unless someone has removed it and didn't put it back sounds like it is flashing a failure code
Whirlpool dishwasher blinking lights! HELP!! (Dishwasher Repair)
by peaches1120 9/5/2013 4:42:44 AM(UTC)
