Hello, My washer/dryer combo fills fine when using the hot water, but when using the cold it barely fills...taking hours. It is intermittent at this point, but is getting worse. What is wrong? Thank you, TammyJJ:confused:
Hi Tammy
The first thing to check is whether or not the filter screens inside the cold water valve are clogged. Disconnect the cold water hose and look at the valve and if it is a problem clean it out with a good brush. Cheap and easy repair. Also check, of course, that you have good cold water coming from the hose.
If that is not the problem, replacing the valve assembly is the next thing to do.
Good luck.
Thank you so much for the answer...we ordered the part and hopefully it will fix the problem. Tammy:o
Great, let us know how things turn out.
