My three year old dishwasher has green clean light that won't go out
does anyone know what my trouble is
the last rinse water didnt heat in the time allowed could be a bad element or thermastat or the board or the water was to cold to begin with put in a diagnosticto clear the code by doing a keypad dance of pushing normal heated dry normal heated dry normal heated dry all leds will light up then push start then push cancel run machine through a cycle see if it does it again if it does you have a problem
