Oven stopped part way through cleaning cycle. Since then display panel does not light up, & oven does not work at all.
I replaced:
Microcomputer Oven Shutdown Thermal Fuse Oven Temp Sensor
Still oven does not work, & no display on control panel.
What else can I do, or replace?:confused:
Please help
You need to check and make sure you have 120volts on the red and 120 on the black and 240 red to black at the power coming in.
