jcooper2
#1 Posted : Sunday, April 24, 2011 2:27:15 PM(UTC)
jcooper2
The first time I notice my double door frig not cooling a friend told me that it sounded like my coils were frozen. I unplug my unit for about 24 hour and it de-iced, after drying up all the water I plug it back up everything worked find for at lease 30 to 45 days and now it has happen again. Any advise on this problem would be greatly appreciated.
Thank In Advance
J Cooper
Fairburn, Ga
#2 Posted : Monday, April 25, 2011 4:18:42 AM(UTC)
Here are the parts
Replacement parts for TFX25JP models | AppliancePartsPros.com
Does sound like a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 4) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this with a screwdriver.
Note it only turns one way.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 230 in Section 3) from the wiring and measure it for continuity, usually around 20 ohms or so.
Looks like your unit uses glass type heater/s and often you can see where it is burned out.
If the heater is OK
Remove one wire to the defrost thermostat (Item 240 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
