looking foe viking burner ignitor p/n
I think I got the p/n from a similiar thread, should recieve part this wed.
believe or not my microwave is starting to have issues too.....when I get home tonight I will get model number and post....
thank you for replying.......
Rank: Administration
Functional parts for Viking ranges, like igniters and spark modules, can be usually substituted by essentially the same part under a different brand, typically for much less. For example, a Viking flat bar igniter may cost $70 or more whereas this universal igniter made by Frigidaire is only about $40: ![UserPostedImage](http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfNjYwNTM5MzAzNS9JQ1cvc290b2hwdHJhcC8%3d)
My only question now is how to connect the crimp ends of my new replacement ignitor for Viking VGIC305-4BSS broiler to the old wires. Just put the old wires in the new crimps and bear down with a pair of pliers? Then shove it all through the hole so the wire connections are outside the oven? How do I insulate these connections? I'm not happy with the pink plastic around these new crimp ends - will the plastic be OK in the heat?
Thanks!
