gpete
#1 Posted : Tuesday, October 16, 2007 8:18:57 AM(UTC)
gpete
freezer and fridge is'nt as cold as it should be. sometimes for a day or two.:confused:
Pegi
#2 Posted : Tuesday, October 16, 2007 10:06:30 AM(UTC)
Pegi
See if the compressor is running or not when it is not cooling, see if the condensor fan motor is running and see if the condensor coil might be clogged making the compressor over heat and cut off till it cools down...
#3 Posted : Wednesday, October 17, 2007 1:59:32 PM(UTC)
Need more info like Pegi asked for. Something is probably not running all the time it should.
