My Display Clock Is Dead For The 2nd Time. I Want To Know Is It Hard To Install One Myself? The Last Time The Guy Did It In 15 Minutes....is It Very Involved Or Can A Normal Person Do It? Anything Special I Need To Know?
The job is rather easy, just verify there is power to it. Also, make sure the oven door gasket is ok, if not, replace it as the heat from the oven will destroy the module real fast.
