HI,
My dryer would not start when you hit the start button but you could pull on the timer knob and it would go.
I ordered and replaced the timer control. The new control solved that problem but now on time dry the timer will not advance.
Where do I go from here?
Thank You Sean Lucas
Model# LER8858EQ1 Serial# MG2501674 Purchase Date 7/31/1997
Verify the timer is putting voltage to the timer motor.2 black wires coming off motor you should read 120.
