CHRIS3560
#1 Posted : Monday, November 3, 2008 9:34:17 AM(UTC)
CHRIS3560
I have a maytag performa dryer that was working flawlessly until last week. It started this intermitent screaming noise while running. Yesterday during a load, it screamed for about 10 seconds then stopped rotating and created a sort of huming noise as if the motor froze up. I tore it down this morning and found that the motor was frozen. After manually rotating the shaft a few times it seemed to free up. When the motor runs now it still screams but IS running. Is there a fix to this like lubrication or should I just replace the motor?
If I do replace the motor, is this difficult or should I have an appliance technician change it out?
Thanks,
Chris Nichols
Yucca Valley, California
Drags1998
#2 Posted : Monday, November 3, 2008 10:58:23 AM(UTC)
Drags1998
Change the motor, Its not hard, but you may want to hire someone.
Guest (4)
