Originally Posted by: kurtmc  Joe, I received the bracket in the mail today, installed the bracket and I have an ice dispenser again. Thanks again for all of your help. Happy Holidays! Kurt, Great job, Glad to hear you're up and running, New you could do it. Thanks for the update, You have a great Holiday as well, :D :D :D
I cleaned the coils, the relay keeps clicking off and on about every 2 minutes, compressor is warm but not real hot. any suggestions? Thanks kurt
Originally Posted by: kurtmc  I cleaned the coils, the relay keeps clicking off and on about every 2 minutes, compressor is warm but not real hot. any suggestions? Thanks kurt Kurt, If you're sure you don't have a low voltage problem, you most likely have a weak overload or relay Part number: AP3083556
Start there. Good Luck, :) :) :)
Ok i will, is it too late to get a part overnighted? Originally Posted by: Joe / APP Team  Kurt, If you're sure you don't have a low voltage problem, you most likely have a weak overload or relay Part number: AP3083556
Originally Posted by: kurtmc  Ok i will, is it too late to get a part overnighted? Kurt, as long as you place the order before 3:00 pm EST, you'll get it the next day. :) :) :)
