what does thi s code mean?
Originally Posted by: lyndasar  what does thi s code mean? Lyndasar, The F2 code would be a problem in the touchpad assembly, not an un common problem on an over the range microwave. F2 Touch panel failure 1. Unplug microwave oven or disconnect power.
2. Replace touch panel.
3. If problem persists, replace electronic control. 4. Plug in microwave oven or reconnect power. Part number: AP3603934
Is the part number for the touchpad assembly, and where you need to start. Thanks, :) :) :)
