I have a whirlpool washing machine that will fill with water but will not agitate or spin. I have check the lid switch and wired it together to eliminate the lid. I as so check the capacitor which also checked out good. The timer sounds weird when I pull out the nob. The timer has never made this sound before, it sounds like something is grinding. When I move the timer between the different cycles trying to get it to work, sometimes the motor will humm. This leads me to think the motor is bad. I also removed the water pump from the motor as well. please Help. timer number:3955499 Motor number: 8528157
Remove The Motor And See If The Coupler Is Broke
Coupler is Good. Motor isn't spinning when timer is put out. But isn't motor locked up
Sorry, Motor isn't locked up
try hooking just the motor to wire harness not mounted to machine with lid switch jumpered in spin will it run?
I would pull the cover off the timer and check for burnt contacts.
