johna56
#1 Posted : Sunday, April 17, 2011 3:26:13 PM(UTC)
johna56
I was changing the coin box when I accidentally touched a wire or something..... I heard a pop and saw a small puff of smoke. now the dyer will not start. I know very little about these machines but am usually pretty handy. Can someone help me troubleshoot this or tell me what the problem moist likely is if I gave enough information to determine the problem. Is this fuse or did I likely blow the motor, or something else?
Thank you.
-john
johna56
#2 Posted : Monday, April 18, 2011 8:18:28 AM(UTC)
johna56
Problem solved.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Kenmore Dryer Problem (Dryer Repair)
by steviebinto 9/17/2009 2:39:18 PM(UTC)
