jdswartz
#1 Posted : Monday, October 15, 2007 9:39:25 AM(UTC)
jdswartz
I'd like to disconnect the buzzer on my Maytag dryer - it is REALLY loud and wakes the baby. I see from the schematic that it is located behind the control panel. If I disconnect the wires, will it impede another part (are they wired in serial)? Or can I disconnect it and leave the wires unconnected? Are there any other issues in doing this?
Thanks!
Pegi
#2 Posted : Monday, October 15, 2007 6:21:14 PM(UTC)
Pegi
Looks like you can just pull the wires off and tape the ends so they do not touch anything metal in the console... WIRING DIAGRAM :)
panvanchan
#3 Posted : Friday, November 27, 2009 12:21:00 PM(UTC)
panvanchan
In case it helps anyone, I finally disabled that aggravating buzzer on my Maytag LDG9316AAE dryer, and attached a photo of the pink wire I detached which I then taped up! The photo is looking at the top right rear of the dryer.
panvanchan attached the following image(s):
