icehouse
#1 Posted : Thursday, October 30, 2008 5:49:54 PM(UTC)
icehouse
Originally Posted by: kengolive Go to Quoted Post
Hello J
I have a common problem in my conditioner and it is (we call it) “excess air in circulating water”. We have a Fan Coil Unit and you should know that the air bubbles in a closed system like any coil system could lead to performance problems. You cannot have the maximum performance if your cool/hot water in the coils has more air within it. So we have to release excess air by opening and closing a valve (bolt/screw) and air is trying to escape because there is always water pressure in a closed system.
(Every FCU has its own screw for escaping air)
Now the question is what is the best situation for releasing excess air? I mean, when the water is circulating or just when the system is shutdown?
1. Release excess air when water (hot/cold) is circulating
2. Release when the pumps are off
I don’t know the difference and the better way for doing this, please help me. By the way, I
couldn
’t find the technical definition/phrase for this “excess air in circulating water”; would you please tell me what you call it?
[FONT='Calibri','sans-serif']Regards,[/font]
Maybe "Automatic Bleeders" that are used on
Hydronic
Systems
icehouse
#2 Posted : Saturday, November 1, 2008 6:13:51 AM(UTC)
icehouse
This is am "excellent book" by one of the leading authorities on the subject.
Available everywhere including my web site HVAC-R Central- Discount Hub for Tech Training-Technical Books-Tools and Appliance Parts
icehouse
#3 Posted : Saturday, November 1, 2008 6:26:33 AM(UTC)
icehouse
icehouse
#4 Posted : Saturday, November 1, 2008 4:21:59 PM(UTC)
icehouse
icehouse
#5 Posted : Sunday, November 2, 2008 4:52:18 AM(UTC)
icehouse
While the water is circulating. As the water heats or cools, air is entrapped. The use of an "Air-Scoop" with an automatic bleeder will solve this problem.
Usually mounted with an expansion tank. :)
icehouse
#6 Posted : Sunday, November 30, 2008 5:45:21 PM(UTC)
icehouse
:mad: Listen here, this is a repair forum. Keep the nonsense to yourself.
icehouse
#7 Posted : Thursday, January 1, 2009 3:41:06 AM(UTC)
icehouse
Who is allowing this garbage to be posted ? This is a repair forum, so let's keep it that way. :mad::mad:
