bmissell
#1 Posted : Saturday, April 16, 2011 6:56:34 AM(UTC)
bmissell
had a lighting strike and board was noticably damaged. Ordered new board - generally looks the same but there are some obvioius differences. I understand that that they can look different but still work the same - the issue I have is that my currnet board has 2 places where 2 prong wire adapters attach. The new board only has one... If this board does work (as the technical support maintains that this is the same board not an upgrade or different one)- which pair of wires do I use and what do I do with extra set!
Let me know if photos will help or if additional information is needed.
Bill
bmissell
#2 Posted : Saturday, April 16, 2011 8:33:17 AM(UTC)
bmissell
Further information. From the wiring diagram it appears that the two circuits are the Secondary switch power relay (RY2) and the turntable control relay (RY3).
On the new board it appears that the RY3 relay is missing. There is a place for it on the board and it is labeled on the board but there is nothing there...
Guest (4)
