10/29/08
I am trying to replace the timer on my Frigidaire washer, can anyone give me instructions on doing this? Any and all help will be greatly appreciated. Thanks in advance.
Barry
remove the top push the knob in so its off then unscrew it turning to the left then remove dial remove the 2 screws holding timer in then bring it up through the top you'll have to remove wires write it down where they go there is a mess of them. Some of those are color coded so you cant screw up to bad
Thanks for the advice I really appreciate you taking the time to answer me.
