Hello,
I have a GE Electric stove that we just replaced the ERC board on because one of the buttons broke. Everything else worked fine before. Now after the install, the oven keeps cycling through the lock and unlock cycle. It does make the clicking noise of the lock engaging. The oven wont turn on for more than 10 sec before the lock cycle starts and kicks out the oven setting. The only time it stops is when I can catch the stove unlocked and open it. Then the ERC board functions normally. As soon as the door closes, it starts all over again.
Any suggestions on how to fix this? I really need my stove to cook!!!
My model # is J DP39W0W2WW and the ERC board that we replaced is part # WB27T10174.
Thank you for your help! Tracy
