EEguy60
#1 Posted : Thursday, April 14, 2011 11:56:40 AM(UTC)
EEguy60
I have been having defrost problems with my GE fridge for ~2 years. During this time, I have simply emptied the freezer, defrosted, and started back up. The unit would eventually fail to cool again, sometimes after a few months and sometimes after only a week. In all cases, both the freezer and refrigerator warm up together, so the problem is not isolated to one or the other.
I have recently discovered through this forum and other sources on the internet how to debug for defrost problems. Unfortunately, everything that I have checked so far seems OK. The heater/thermostat appear good, measuring ~22 Ohms at the J1 cable at the main board, and the thermistors also measure correctly. In fact, I bought a thermistor to replace the evaporator one, suspecting this as the problem. I clamped the new and the existing ones together, let the unit run for a while to stabilize temperature, and then measured both thermistors; they both read virtually the same impedance. Finally, all fans appear to be running correctly.
Based on this info, I am wondering whether the heater is ever getting turned on. Is there a way to force the heater on so that I can verify whether it is getting powered? Is the power applied through one of the relays on the main board? I would love to get a wiring diagram, main board schematic, and/or service manual to assist in the diagnostics.
I have little desire to simply replace the rather costly main board. I am an electrical engineer and am capable of repairing the board if I only know what to look for. Before these defrost problems began, the refrigerator quit working because the input flyback converter that generates the 14V to power everything failed. I repaired and improved the flyback design and also had to replace the ice dispenser solenoid at that time. Perhaps the heater control relay was overstressed when the converter failed. Other than the defrost issue, the unit has continued to work fine since my original repair.
I appreciate your assistance in fixing this problem.
#2 Posted : Friday, April 15, 2011 12:57:27 AM(UTC)
Replacement parts for General Electric PSS26SGRESS Refrigerator | AppliancePartsPros.com
Here is a manual
31-9072 Arctica Profile GE Side-by-Side Refrigerator Service Manual - ApplianceDigest.com
Although it does not specify a PSS26 it may be close as it is for the PSS series.
Here is info on the defrost.
31-9062 GE Refrigerator Adaptive Defrost Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
[COLOR="DarkRed"]Is there a way to force the heater on so that I can verify whether it is getting powered?[/COLOR]
Try the diagnostics in the manual.
[COLOR="DarkRed"]
Is the power applied through one of the relays on the main board?[/COLOR]
I believe it is one of the relays but am not 100% sure of this.
Should be easy enough to trace it back.
EEguy60
#3 Posted : Friday, April 15, 2011 6:08:12 AM(UTC)
EEguy60
Thank you for the links to the manuals and the feedback. Hopefully, I will be able to figure out my problem with this diagnostic help.
This morning, my hypothesis from yesterday about the heater not being activated was blown out of the water as I found the coils completely defrosted when I opened the freezer. The condenser was not running, and the freezer temp was at 2° when I first opened the door. The condenser came on after a few minutes but the temperature rose to 7° before I left for work; it is now back to 5° after ~2.5 hours. Frost was on the coils, and it seems to be operating correctly. The freezer is nearly empty, so I expect that this accounts for the wide tempertature swings, as the refrigerator is currently at 35° with a setpoint of 37 or 38.
This doesn't seem consistent with my previous defrost problems, but maybe I have reconnected something during my testing. As I reported yesterday, there is continuity on the defrost thermostat (which I only measured along with the heater). Since the freezer set point is 0°, I assume that it is normal for the hysteresis to be a few degrees before the condenser cycles back on. Is this correct?
Thanks again!
#4 Posted : Friday, April 15, 2011 10:17:39 AM(UTC)
Yews I would not sweat a little temperature variation.
One thing you may want to check is the defrost thermostat (Item 240 in Section 4 of the parts) for any sign of bulging. This can often cause them to go intermittent.
Kitchenaid Undercounter fridge defrost problem KUDF204ESB00 (Refrigerator & Freezer Repair)
by glenn.anderson82@yahoo.com 6/14/2021 6:41:38 AM(UTC)
Fridge defrost problem (Refrigerator & Freezer Repair)
by Leeowens 12/15/2017 9:14:42 AM(UTC)
GE Defrost problem (Refrigerator & Freezer Repair)
by acap 6/21/2011 7:08:55 AM(UTC)
GE defrost problem (Refrigerator & Freezer Repair)
by Alex2 8/2/2010 5:24:03 PM(UTC)
GE defrost problems - question (Refrigerator & Freezer Repair)
by paulcg 6/21/2010 1:47:27 PM(UTC)
Dreaded GE defrost problem (Refrigerator & Freezer Repair)
by SweetSwede 10/28/2009 10:57:57 AM(UTC)
by casadeagua 12/11/2008 7:37:57 AM(UTC)
