aitsjustsean
#1 Posted : Thursday, April 14, 2011 9:52:06 AM(UTC)
aitsjustsean
My Dish washer fills up and drains It hasn't been used in years I cleaned it out but now it doesn't work i don't hear anything moving but water when I think it should be cleaning it just hums should my bottom arm be turning all away around because it gets caught on the heating element it doesn't move at all am i missing a piece? does my garbage disposal have to be working in order for my dishwasher to work? Thanks for the help
Joe / APP Team
#2 Posted : Friday, April 15, 2011 8:56:08 AM(UTC)
Joe / APP Team
Aitsjustsean,
Since you haven't used the machine in years, chances are the impeller and motor seal has seized up, and the motor wont run. Most of the time, you can remove the motor and turn the impeller, and the motor will run properly, some times you can turn the cooling fan(also part of the motor) with the same results. Or you'll need to replace the motor assembly.
Are you sure the lower spray arm is catching on the heater element ? could it be, that theres something in the tub or between the walls that would block it from spinning ? Look and make sure the arm and nozzle assembly are not bent.
No , your Garbage disposal should not need to be running in order for your dishwasher to run.
I'm sure, once you check the motor, you'll be OK.
Good Luck,
help me please (Dishwasher Repair)
by jeaniem 7/24/2013 8:26:01 PM(UTC)
Can you help me please. (Dryer Repair)
by nickon 12/6/2011 3:22:53 PM(UTC)
Help me please! (Washer Repair)
by datonyariley 10/31/2011 3:16:56 AM(UTC)
Help me please (Refrigerator & Freezer Repair)
by jek2gdkb 2/24/2011 10:14:19 AM(UTC)
Help me please (Dryer Repair)
by ksheff 4/27/2010 4:46:16 PM(UTC)
Help Me Please!!! (Washer Repair)
by marcelfaison 9/8/2008 1:16:41 PM(UTC)
