Katnatbobchris
#1 Posted : Wednesday, April 13, 2011 11:13:29 AM(UTC)
Katnatbobchris
We have an admiral gas dryer ADG7000AWW that will not heat, I have read thru some previous posted but I am not sure if the tips are the same for our dryer. We tried bypassing what we think is the thermal fuse to see if that was the problem but same results. We have also taken the front off and cleaned the whole thing out, lots of lint everywhere. We did not realize the vent house had come off the back and I think that is why there was so much lint. Also we checked it on both timed dry and auto dry, neither setting gets heat. Any suggestions?
#2 Posted : Wednesday, April 13, 2011 1:18:30 PM(UTC)
You have to have a simple multimeter to perform the troubleshooting. Let us know when you ready and we'll guide you through the tests.
Here are the breakdown diagrams and Replacement parts for ADMIRAL ADG7000AWW DRYER- GAS | AppliancePartsPros.com
Katnatbobchris
#3 Posted : Wednesday, April 13, 2011 3:38:34 PM(UTC)
Katnatbobchris
Ok we will get one tomorrow and be ready to start testing. Thank you for replying so quickly.
Katnatbobchris
#4 Posted : Sunday, April 17, 2011 5:06:40 AM(UTC)
Katnatbobchris
Hi we have the multimeter and just need to know the next step. We were hoping to be able to work on it this weekend. Thanks! :)
Katnatbobchris
#5 Posted : Wednesday, April 20, 2011 4:18:33 PM(UTC)
Katnatbobchris
We are ready to start the testing, we have the multimeter, what are the steps for testing? Thanks!
Katnatbobchris
#6 Posted : Wednesday, April 20, 2011 4:19:17 PM(UTC)
Katnatbobchris
We are ready! What's next?
#7 Posted : Thursday, April 21, 2011 12:54:34 PM(UTC)
Sorry for the delay.
You can find the troubleshooting instructions in one of our previous threads: http://forum.appliancepartspros...3-no-heat-gas-dryer.html
Those parts in your dryer are shown as:
The cycling thermostat - #13 on the diagram.
The flame sensor - #13 on the diagram.
The high limit thermostat - #14 on the diagram.
The thermal fuse - #15 on the diagram.
The igniter - #11 on the diagram.
The gas valve coils - #2 on the diagram.
- The cycling thermostat Part number: AP4039476
- The flame sensor Part number: AP2910747
- The high limit thermostat Part number: AP4055834
- The thermal fuse Part number: AP4056527
- The igniter Part number: AP4038992
- The coil kit Part number: AP4009392
Fireman Lloyd
#8 Posted : Tuesday, June 28, 2011 4:51:49 PM(UTC)
Fireman Lloyd
Hi Gene. I noticed your in Orange County. I am a fireman in OC but live in Illinois. I am trying to help my 17 yo son figure out why the dryer wont heat. This over the phone. He has my dig. multi meter and I can talk him through the troubleshooting, but we cant figure out over the phone how to get to the ignitor and other parts. The last dryer I worked on had a kick panel on the front bottom of the dryer. This admiral ADG7000AWW apparently does not. Could you please tell me how to get into the dryer to check the electricals. Thankyou Lloyd
#9 Posted : Wednesday, June 29, 2011 1:53:52 PM(UTC)
Hi Lloyd,
Remove the top cover by using a plastic putty knife to depress the locking clip between the top cover and front panel. Lift the top cover.
Draw a picture on how the wires are connected to the door switch and remove the wires from the door switch.
Remove two screws, one on each side, from the back flange of the front panel.
Tip front panel back and remove.
Admiral gas dryer not heating properly (Dryer Repair)
by moonflower23 2/4/2012 10:35:54 AM(UTC)
