Gman60
#1 Posted : Wednesday, April 13, 2011 6:18:17 AM(UTC)
Gman60
Refrigerator side and freezer side are not cooling properly, and noticed ice buildup on freezer side at the back.
Since this unit is 13 yrs. old, is it worth repairing? What do you think is the problem?
Thank you.
#2 Posted : Wednesday, April 13, 2011 11:36:20 AM(UTC)
I cannot find any info on the given model number. Tried here, the sears site and the Frigidaire site.
Please check it.
If this is a non USA model info may not be available.
Try to see if it uses a defrost timer or an adaptive defrost board.
Timers may be located in the machine compartment under the unit often at the front.
They also mount them in the control console at the to[p of the fresh food section. There is often a hole to allow you to turn the cam with a screw driver.
The cam only turns in one direction.
For a timer system
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Also here is a good link with basic fridge repair info which should come in handy. It has how to force a defrost with an adaptive board on most Frigidaires who actually made your unit. See #30.
http://www.applianceaid.com/refrigerator.html
