meforsteruk
#1 Posted : Wednesday, October 29, 2008 12:36:50 AM(UTC)
meforsteruk
I'm in the UK. How do I replace the aquastop. I am having to manually drain the base so the the float doesnt keep tripping the microswitch every 3-4 days. I have noticed that the chamber leaks into the moulded base from the aquastop unit and that the float/switch is sensitive to any water in the base. Once i have emptied the water the washer works fine on all programmes (Intensive 70c, auto 55-65c, eco 50c, glasses 40c, quick 35 and pre-rinse). The aquastop is located at the bottom of the left side tank that fills with water that is to be used for the next instruction (like rinse or wash).
#2 Posted : Thursday, October 30, 2008 12:06:17 PM(UTC)
Unfortunately there is no on-line access to any diagrams or other information for not American models.
misterfixall
#3 Posted : Thursday, October 30, 2008 2:37:02 PM(UTC)
misterfixall
quite possibly there is a problem with fill valve which allows execessive amounts of water under pressure in
