gmorris500
#1 Posted : Tuesday, April 12, 2011 12:45:12 PM(UTC)
gmorris500
I have a Whirpool GH5184XP microwave / oven hood combo, that blows the circuit breaker only when the cooking function is started. The clock, timer, fans, lights, and all other functions work. When START is pressed, however, the microwave runs for half a second before the circuit breaker trips. It is plugged into a dedicated circuit on the house wiring.
The inverter board has wiring with what seems to be heat damage (like dried-out looking insulation on wires, tiny burned spots, etc.), so I suspect it is the problem.
My questions are:
1. Are there other problems that could either cause the same symptoms?
2. How do you discharge the capacitors on the inverter board? There is no HV capacitor listed on the parts list, and I haven't seen one inside the microwave.
3. Are there any other parts I should test before putting in the inverter board?
#2 Posted : Tuesday, April 12, 2011 4:06:16 PM(UTC)
The first thing I would do in such situation is plug the microwave in a different outlet with a different circuit breaker to see how it will work.
The model number you posted is incomplete. Verify and repost it.
Microwaves with inverter board do not have high voltage diodes, capacitors and transformers.
gmorris500
#3 Posted : Tuesday, April 12, 2011 6:19:25 PM(UTC)
gmorris500
Model number is GH5184XPS, sorry about that.
I plugged it into another circuit, but now the fuse inside the machine is blown, and it's completely dead.
gmorris500
#4 Posted : Tuesday, April 12, 2011 7:12:50 PM(UTC)
gmorris500
Replaced the fuse, plugged it in - POP - fuse inside the machine blew as soon as I plugged it in. Any ideas?
#5 Posted : Wednesday, April 13, 2011 12:03:54 PM(UTC)
Check the monitor switch (#10 on the diagram) and both interlock switches.
It's still missing one digit in the model number after "S".
vin14
#6 Posted : Friday, June 13, 2014 12:11:01 PM(UTC)
vin14
How did you fix this problem on your microwave? Did you replace the inverter board or something else? I have the same microwave with the same symptom so if can please let me know how you fix yours I would really appreciate your help. Thank you! Vin
