S Brown
#1 Posted : Thursday, October 30, 2008 6:44:37 AM(UTC)
S Brown
Oven temp is off 100 degrees is there a problem with thermostat or can be adjusted? how do you adjust thermostat?:confused:
S Brown
#2 Posted : Thursday, October 30, 2008 9:46:03 AM(UTC)
S Brown
oven temp is off 100 degrees is there a problem with thermostat or can it be adjusted? how doyou adjust thermostat?
v2k04
#3 Posted : Thursday, October 30, 2008 9:50:27 AM(UTC)
v2k04
If your thermastat is off that far it needs repalced if it's consistant and always off by that amount. Compensate it in the knob 100 degrees
