bigubomb
#1 Posted : Thursday, March 17, 2011 7:36:12 AM(UTC)
bigubomb
I have recently replaced the shifter coil and motor inverter, so i have completely disassembled the machine twice during that ordeal. It works great but as it gets to the spin cycle it acts unbalanced and makes a god awful noise everytime it gets to the spin cycle. The deal is it is really not an unbalanced load, i can simply open and close the lid and the cycle continues without problem. I did not have any spare parts when i reassembled the machine, so i don't know what would cause this problem.
Thank you for your help and don't be too hard on my workmanship.
sidfink43
#2 Posted : Saturday, March 19, 2011 3:51:35 PM(UTC)
sidfink43
Well not only would we not criticize your work, we would express our admiration in that you made those repairs.
About the only good suggestion I can give you is to operate the machine with the front cover off and see if the problem presents itself. If not, replacing the support rods/spring assembly would be a good way to start trying to fix it.
bigubomb
#3 Posted: : Thursday, April 7, 2011 5:18:24 AM(UTC)
bigubomb
Hey guys thanks for your help and support. I took the machine apart again and i found that the large aluminum hub nut was stripped allowing the basket to shake around in the Tub. The hub nut and a new split ring solved the problem. Thanks again guys.
sidfink43
#4 Posted : Thursday, April 7, 2011 12:36:22 PM(UTC)
sidfink43
Great, glad you got it fixed and thanks for the update.
bigubomb
#5 Posted : Monday, April 11, 2011 5:21:14 AM(UTC)
bigubomb
I have one more quick question. Do i need to put something like a lock tight on that hub nut to keep it from loosening. Thanks again.
sidfink43
#6 Posted : Monday, April 11, 2011 6:21:26 AM(UTC)
sidfink43
No it should be fine with enough torque, well actually a lot of torque.
From the Service Manual:
The hub nut must be torqued to 75 ft. lbs. To ensure
the hub nut is tighten sufficiently when using a hub
nut wrench, align the wrench with the holes in the
basket and use them as a guide to determine when
the nut will not move any further. Impact wrenches
are set to more than 75 ft. lbs. and should tighten
the nut sufficiently.
bigubomb
#7 Posted : Tuesday, April 12, 2011 5:32:09 AM(UTC)
bigubomb
Awesome. That is what i needed to know your a life saver.
sidfink43
#8 Posted : Tuesday, April 12, 2011 10:23:08 AM(UTC)
sidfink43
Great, good luck with your machine going forward.
