mtokas
#1 Posted : Tuesday, April 12, 2011 4:31:43 AM(UTC)
mtokas
Washer will not go into final spin when water level is set to small load,but will spin on all other water level settings.
sidfink43
#2 Posted : Wednesday, April 13, 2011 6:02:25 PM(UTC)
sidfink43
Well this is just plan weird since the two functions should really not have much to do with one another.
I would clean out the tube from the water level switch to the tub and see if that helps. Other than that nothing really comes to mind except changing out the water level switch but I can't say I am in love with that recommendation.
