Hi, I have a relatively new Kenmore stove/oven that came with the house I just got. After a power outage, it has not worked. The clock, outlets, and oven light all work. All four ranges and oven do not. I checked the fuses on the top of the stove and they are fine. Also at a brieg glance, the wiring seems to be Ok, although I didn't check the wiring past removing just the smaller back panel. Any thoughts or do I need to bite the bullet and call a repair person? I should also mention that I am not a handy woman so any guidelines should reflect that. Thanks so much, jo
Is it gas or electric?
If it's electric then it suppose to be a double circuit breaker in the breaker box and both breakers must be "on" and it suppose to be 240VAC at the power outlet for the range.
The model number you posted does not come up. Is it American model?
