glassz
#1 Posted : Wednesday, October 29, 2008 2:52:01 PM(UTC)
glassz
I cannot find the model number for my washer in the list and I need a part.
The needed part connects the hose to the fabric softener dispenser. My hose has a broken piece of plastic on the end which I believe broke off of the dispenser. I don't know if there is just a connector available or if I will have to purchase the dispenser as well.
The hose flops around in the tub while I'm using it and water shoots everywhere, eventually winding up on the floor. I have to lay towels around the base of the washer in order to use it.
I apologize if this posted twice. The first attempt said I wasn't logged in (but I was). :D
Any help would be greatly appreciated.
Glassz in Bama
libertyappl
#2 Posted : Wednesday, October 29, 2008 3:48:22 PM(UTC)
libertyappl
This is the #0 model but is the same as your #1
Model KAWS850LQ0
Nat
glassz
#3 Posted : Wednesday, October 29, 2008 4:40:37 PM(UTC)
glassz
Nat, thank you for the quick reply. I had looked at the "0" model but the part looks different than mine so that's why I posted the question.
I realize they may have redesigned it since I purchased my washer but I was afraid to take a gamble on whether it would fit without someone much more knowledgeable than I.
I'm going to order the part and again, thank you so much for your help.
Glassz
