Have Whirlpool Gas range Model#SF265LXTS. Burners work without a problem. Oven does not light....correction: sometimes it will, but MOST times not. Will set oven for baking. Oven will click, click, click, and then it sounds like it shuts off. Process repeats itself every 2 mins or so without any ignition or heat.
If it does work, then, during baking, oven kicks on every 30secs or so. "click" then hear the gas flow, then "click" and gas flow stops. Process repeats itself during baking. Very inconsistent. Have had sensors replaced.
at a loss. can you help?
If it's less than a year old call Whirlpool custoer service and have them send a tech out. 800-253-1301
Nat
