13 Pages«<56789>»
#61 Posted : Wednesday, April 6, 2011 11:24:18 PM(UTC)
Originally Posted by: johny2thumbs Go to Quoted Post
Im unable to begin a new posting, so Im jumping in on this one..
My model wwse5240g0ww is a no agitate spin
I did a continuity test from wall plug ends to motor plug
I have powers and ground present at motor
It fills and drains
The 2 prong to device on shaft Ohm's out good
Good LEDs with no fault codes present
GE reset = nothing..
Thanks in advance for your time and talent.:)
You may want to check the inline fuse for continuity. The instructions are attached.
- The fuse link Part number: AP4390012
Here are the breakdown diagrams and Replacement parts for General Electric WWSE5240G0WW Washer | AppliancePartsPros.com
File Attachment(s):
Fuse location and diagram.doc (238kb) downloaded 55 time(s).
johny2thumbs
#62 Posted : Thursday, April 7, 2011 5:06:33 PM(UTC)
johny2thumbs
Hi Gene,
thanks for the recommendation about the fuse,
I assume it is good as I have power present at the motor at orange and red white wires.
The good news is when leaving home Depot I saw a scratch and dent washer for $150 !!! so I packes it uo got it home swapped out the top/lid assembly and away we go.:) .
I bought an extended warrant and will use a seperate ground wire and get a surge protector for it too.
nMean while on my porch sits a mystery. Ill check the low voltage side
before I chuck it,, seems I should have gotten more than 4 years out of it..:mad: Thanks again Gene! Your the man!!:D :D
plantlady64
#63 Posted : Friday, April 8, 2011 8:53:04 PM(UTC)
plantlady64
My washer is a GE but the model number is WDSR2080D8WW.My washer washes and drains but won't spin. Could mine have the same fuse problem? Or do you think mine could be a timer problem.The belt is in great shape. My washer is also 5 years old. Thanks Carla.:confused:
#64 Posted : Monday, April 11, 2011 1:59:33 PM(UTC)
Carla,
Your washer is very different. Does the motor run when it comes to spin?
Here are the breakdown diagrams and Replacement parts for General Electric WDSR2080D8WW Washer | AppliancePartsPros.com
plantlady64
#65 Posted : Tuesday, April 12, 2011 6:43:25 AM(UTC)
plantlady64
yes it runs it goes thru all cycles just won't spin out clothes.makes the noise like it wants to spin but don't.then finishes it't cycle.it didn't even smell hot when it did it.
plantlady64
#66 Posted : Tuesday, April 12, 2011 6:49:36 AM(UTC)
plantlady64
It goes thru all cycles. It just won't spin. It sounds like it wants to but the clothes are soaked. There is no smell at the end of the cycles either.Like a hot smell:confused:
#67 Posted : Tuesday, April 12, 2011 9:01:30 AM(UTC)
Remove the front panel by pushing in the release tabs under each side of the front panel.
When the washer is in spin, see if the tranny pulley is turning.
Xdriver
#68 Posted : Sunday, June 12, 2011 2:22:38 PM(UTC)
Xdriver
I have a Ge top load washer model number wpre6150k2wt that pumps out water but does not agitate or spin. I have tested the lid switch with my ohm meter between the plug and the gray wire on the motor (left bank of wires, the one opposite the green) and it has continuity.
I tested the far right bank of wires and the #4-5 and #3-5 both have 12VDC
The 2 wire plug with red and yellow have about 98ohm
I have tried resetting the controller board and do not see any flashing green lights.
Does this mean my motor is bad, if it does mean this, my motor part number is 175D5106G057 and I am unable to find it on your site. Please help. Thanks so much.
#69 Posted : Monday, June 13, 2011 5:50:33 PM(UTC)
Xdriver,
Sounds like the problem is a bad in line fuse. Use the instructions posted earlier in this thread, addressed to [COLOR="Red"]johny2thumbs[/COLOR] to locate it.
Xdriver
#70 Posted : Monday, June 13, 2011 6:06:21 PM(UTC)
Xdriver
I forgot to mention that I tested the inline fuse and that is also fine.
Guest (10)
GE washer will fill and drain but no spin/agitate (Washer Repair)
by Montana_Pete 9/12/2008 6:00:02 PM(UTC)
13 Pages«<56789>»
