Have error code EO FO, replaced thermal fuse after self cleaning and it would not heat. Now heats, but the temp control when you start it, starts at 350, if you push temp up button, temp actually lowers to 345, 340, 335. If you push temp down, continues to lower.
Check the conntections to the control board, if not loose you will probably need a new ERC. Nat
OK the contol board is the computer chip board looking thing on the inside behind the touch panel right. And if need new ERC, that is that computer chip thing, not the whole touch panel and membrane, is this correct
That is correct the ERC is the control board, which looks like a computer board. I can look up the part numer if you need it. Nat
that would be helpful, I have microcomputer # 4452240, but then I had AP3055300 number, don't know if they are the same thing or not?
The 4452240 is the correct manufactures number. If ordering from this site use AP3009794(which is probably your cheapest route). This company is one of the cheapest on retail sale parts. I just volunteet to help people find parts and hopefully solve their issues with appliances. Nat
