Bill Demetros
#1 Posted : Tuesday, October 28, 2008 8:23:51 AM(UTC)
Bill Demetros
I have ordered part 10442402 and received part 10442411 as the correct part to use as replacement. My problem is that the white connector on the new part is long and square and the connector on the part I pulled out is a round tube type connector. Do I need to replace the connectors on each end or can I cut off the connectors and hard wire the wires together?
libertyappl
#2 Posted : Tuesday, October 28, 2008 9:42:29 AM(UTC)
libertyappl
Bill you can cut the wires and connect them together, I would recommend using a crimp type connectors.
Nat
Defrost thermostat replacement (Refrigerator & Freezer Repair)
by tommyrob 1/22/2013 2:41:36 PM(UTC)
by kelly b 6/23/2009 1:06:33 PM(UTC)
